Hello using RW8 and foundation stack - I have 5 logos that need to be side by side along the bottom of the desktop page but go unbeaten each other on mobile. I cannot figure out how to balance the 5 logos - get off spacing ie. left and right are on 3 and the 3 centre logos are on 2 which makes 12 columns but this also means the logos at each sides are bigger!! How do I get all 5 logos to be the same size, centred and fit all on 1 line with same spacing on the desktop view??
I used the 5 column stack should I use the 7 columns stack and add spaces? Please help
