RW7. I want to remove all unused stacks, etc from the project library. When right+click on any of the Foundation items, uninstall is greyed out. Is it that the only way to uninstall them is to delete from the Library folder for RW?
tia
tia
All of the foundation stacks come from combined stacks file…
Just do a Show in Finder…you will find the Foundation stack and maybe 2 others…add on ones from @joeworkman, if you remove those…and reboot they will be removed.
Thank you.
