Foundation issues
I still have Foundation 1 stacks and theme on my system, how can I remove them so that I don’t accidentally select the wrong ones?
Also, I get the stack/theme mismatch error; Themes is v6.19.3, Stack is 6.11.11 and checking for updates for Stacks shows no update available. So, how can I get rid of the message or actually force a Stack update?
Hi @Gremlin,
Usually you can just delete them from RapidWeaver’s Settings like so:
Right click if using a mouse, or control click if using a trackpad on the theme, plugin, or stack you want to delete, then select the delete option.
If that doesn’t work let us know.
Which of these are not Foundation 6… or is the answer all of them Prt from Foundation 6 :slight_smile:
Only the 1st item has to do with Foundation 6. The addon packs and the starter pack are from Foundation 1. The others are just other 3rd party stacks.
Thanks :slight_smile:
