@joeworkman It looks like there’s an issue with the advanced padding feature. The R (Right) padding is actually the Left. And the Swatch always shows 0 padding applied. See screenshots.
I wanted to keep the amount of data displayed at a minimum so it does only display small.
I will look into the bug though. Thanks.
Yes, thanks to you both. That display issue makes sense. It would be nice if the Right and Left padding were swapped, or whatever to get them working as displayed.
Fixed. It will be in the next update.
