Heading Text Alignment
Heading Text alignment doesn’t seem to work when it is placed in a container.
If put it in grid item then I can control alignment.
Hi Kevin,
it is possible, but the default margin is currently set on margin left and right to be ‘auto’ - this is causing the heading to centre aligned within the Container.
Changing the margin left and right to ‘0’ will ensure the text alignment works inside a Container.
We’ll be improving the alignment options in upcoming betas :slight_smile:
