Is there any way to get [this hover result] (HANAH - Ingredients) with stacks? I looked at about 10 different stacks but none seems to have exactly what I want. I get that I need a grid stack - recommendations for the hover effect? Thank you!
Take a look at Big White Duck’s SectionsBOX stack. It can be a bit tricky to get your head around but there are demo projects you can download and tinker with and it’s a superb stack.
http://sectionspro.bigwhiteduck.com/box/hover-captions/
This another free alternative - not the exact effect, but pleasing nevertheless. http://www.weavium.com/stacks/image-card
I’ve used it here to create a simple hover effect for the three illustrations.
Maybe this stack can help you out too: CaptionOnImage
SectionsBox will do it for you, it’s really powerful. Here’s a tutorial I made on how to create hover activated animations with it. Of course this applies to ANYTHING that you insert in the stack.
And here’s a blueprint of my setup: https://goo.gl/jNrjFc
Thank you! This might work if the caption can cover the entire page as in the example. I will study the examples some more.
I will give them a try. Thank you!
You could take a look at one of my Freebies to get started. You might even be able to use one straight out of the box.
http://bit.ly/rjh-store
