Hi there,
I created some blogs in armadillo. But I dont need them. How can I delete the ones I dont use?
Thanks in Advance for a short help
Alexander
Hi there,
Alexander
Hello.
If you go to the Pages tab you will see the blogs listed as “Pages”.
Just click the one you want and delete it.
It will ask where you want the posts to go also. If you don’t want them to go anywhere, you may have to delete the posts first. I’m not sure about that.
Might want to make a backup of the Armadillo databases first though. Would probably have to do that through the server.
Paul
Paul,
Thank you very much. That was it!
Have a great weekend👍🏻
Alexander
