“I have an image that is fully visible on a 2XL screen. On an iPad screen, a part of it is cut off, but I want to display it fully there as well. How can I achieve that?”
Try these settings in the Image Component:
Hmmm, depends on how you have it setup…
If it’s an image, you might want to set up a custom size for each breakpoint.
If you share the project or show how you have it set up we’ll be able to better advise ![]()
