I appreciate I am asking support in the wrong place, however I have yet to get a reply and suspect someone here is already using these stacks: “Kuler SQL Stacks”.
I have wanted, ideally an example project to work from, I appreciate mysql db entries and references will vary per user, but having a layout would help somewhat.
I purchased “column” and Kuler MySQL stacks in order to create a layout of products from a mysql database and I am now stuck.
If anyone has used them before and could throw an example together and share it somewhere it would be much appreciated to get me started
The problem you are going to have is that most items that would use this to view the database would have proprietary information stored in the DB so I really don’t think there are a lot of people that would be willing to just share their IP with you.
I was looking through some of my old projects to see if I could assist, unfortunately you would also need access to the MySQL database for it to be functional and that is not something I would be comfortable with.
My suggestion is to search YouTube or Vimeo for Kuler SQL stack. There are good tutorials out there.
