hi im having an issue with my rapidweaver site. Its been stalling while loading and generally slow - i presumed this to be an image size issue so resized everything - also the stalling isnt repeated on certain images so im at a loss at what the issue could be.
so i saved any larger files out to around 250kb but still having the same stalling - does it load the whole site up at once? is there anything i can do to improve this?
Seems to load pretty quickly for me? This is a long shot…but I’ve recently had issues with my dynamic IP address becoming “unpopular”/flagged by my internet service provider due to constant publishing from within rapidweaver. It seems some server side software mistook my efforts as a dns attack (I presume). It’s happened twice, and only affects the site I am working on, and only from my public ip. The observ d behavior is similar. Each time my isp has released my IP address and once a new one is assigned…voila…issue fixed. While I doubt this is your exact issue, perhaps it’s a reminder to look at less obvious causes? Have you tried the site from various networks and computers?
sounds similar but if i load on my phone i get the same issue. performance is better image to image but if you click through a whole gallery it seems to stall at some unpredictable point…
is anyone else seeing the same issue? for me it loads much faster - all images are 200-350 kb
but is still stalls at unpredictable points - ive tried on different networks and macs and experiece the same issues - has anyone any idea what this might be?
