Can’t seem to get rid of the left and right white space for my google map.
The iframe is setting a fixed width of 750px. It won’t grow beyond that fixed setting.
You can change the deminsions there or try setting width to 100% and see if that helps.
Thanks for the help, changed it to 100% no change. The map actually doesn’t expand to 750 even though it is in the code.
Share a url so we can have a look
Solved thanks for all the help. I adjusted the HTML frame to fill mode. i had it set to fixed width 750.
