How do you create a navbar on top of a slider in Foundry or UIkit3? I would like to create a page with the sliders the background and the Navbar on the slider, not sure that makes sense, Anyone has an idea?
Donāt have UI Kit but in Foundry, try this.
- Use a Banner stack set as āHero Bannerā with Banner style set to āimageā
- Add a Mega Menu stack (this is sold separately in the Potion Pack)
- Set navigation to Sticky
- Select āuse alternative colours when stuckā
- Select āpair with parent bannerā and make sure the location is set to āTopā
- Alter the background colours of the menu to suit.
Alternatively, I believe you can just drop the standard Foundry Navigation stack inside Big White Duckās free Chroma stack and use its settings to achieve the same result.
HTH
Rob
Awesome Thank Rob, have a great day
Iām away from my macā¦
It can be done
https://preview.egomade.com/ultimate
You could also use Target for this as well.
In UIkit3 one way is to add a Section to the page, collapse the margins. Add your sider to the Section, if you want to restrict the width, add a Container stack first. Next, under the Slider and Container but inside the Section, place a Position stack, set to āTopā. Then put your Navbar inside the Position stack.
Sounds complex, but itās really not. Itās just a case of building up what you want using the individual stacks. Thatās the beauty of UIkit; use only the stacks you need, thus reducing the amount of redundant settings in large stacks, thus making it really fast.
This is essentially what youāll end up with, only in this instance the navbar is positioned bottom not top.
I see⦠Please share⦠Thank youā¦
JOE⦠You are a God in disguise⦠Thanks⦠This software is helping me with the issues of coding and web development. I hope there will be new and more Updates in the process⦠Thank man
Not for one second saying you shouldnāt buy more stacks, but why buy a stack to do something that is simple to do in either of those frameworks?
You know what, You right, But sometimes some of the stacks can be helpful in other ways⦠But i mean you have a point⦠Until the person full understand all the stacks and suck, why not
imho, that is what so
cool
about RapidWeaver is you can solve an issue in more than one way:
For the knowledgeable
, use coding or css etc.
For the programming challenged, there is a stack
Iāve nothing against Joe or Target, Joe is a great dev and target I hear is very handy, but Ico is right, there is a stack for that, and in the case of the two frameworks you mentioned, youāve already bought the stack, itās in the bundle.
But hey, money, water, etc.
Its funny you do it that way⦠Because I was thinking of the same way to do it. But I realized if you use mega menu At the bottom of the settings area. there is an option to integrate the menu within the banner, weather if you use the Banner or slider Stacksā¦
