I have the below code in the sitewide code section. Using the Tiger Pop theme it produces this result http://pvc-sn3.com/
The customer want the text “within” the rails not to the left as it is now. Any suggestions?
While the image is the background upon which the text sits, thats not going to be possible. Adjustments to the text position will impact the background image causing a relative degree of disconnection between the vertical track connectors.
Would you be willing to tolerate that? If so use:-
#navcontainer a {
background-position: 0px 10px;
If not, then its time to start thinking about how to layer the nav text over the background to enable adjustment of the text without causing a relative (and negating) shift in the background image.
