NEW for RW Elements - fleXon Design Library
Dear Elements Weavers,
I just released something I am working more than half a year now. It is a design library for RW Elements. What does this mean? You are getting a collection of currently 74 ready made designed sections. No matter if you need something for a header, a hero, a Call-To-Action or a footer, in fleXon you will find design solutions for your needs. They fully support the Elements template system as well as Light/Dark mode. No need to say that all sections are fully responsive. Create your website in minutes and not in hours or days.
I am especially proud of the hover sections
https://flexon-elements.weaverpixel.com/hover-box/
As well as of the hero sections
https://flexon-elements.weaverpixel.com/hero/
But all the others are also well-designed. I hope you will like them!
You can use fleXon as a project file or what makes more sense as a component. Installed as a component, it is available beside the Core Library in every project. The elements out of the Core Library and the ones out of fleXon can be mixed and matched as you like, thus enhancing your possibilities even more. fleXon complements what the Core Library already delivers.
Are there further plans? fleXon already delivers 74 segments, that sound like a lot, and it was a lot of work. But there are obvious gaps which should be filled. So I plan every month an update to increase the number of sections over time. If you want to have something for your needs, simply drop me a PN, and it will be included in one of the updates.
As fleXon is new and probably not perfect, it will be available for early adaptors for a special price of $49.99 (plus tax).
More details are on the marketplace
Or here the direct purchase link
And … immediate purchase :slight_smile:
Thank you Jan @Fuellemann :grinning_face:
I’ve been wondering when the templates would arrive :wink:
As always, great work @WeaverPixel, and I’m already looking forward to seeing more of your projects!
Nice work @WeaverPixel, very impressed.
Thanks you @Pegasus and @ajenks ! Means a lot to me, that the “old” Rapidweaver guys like it :+1:
Not a criticism but your back to shop in preview button is not working! However the work you have done is excellent.
@WeaverPixel will there be updates for this project? (are those free or do we have to pay for those)
Greetings,
Mike
Thank you @PMUK for this hint. It is corrected!
Hi @MikeV ,
the updates for fleXon will be free as long as it is in Version 1. If there will be in the (far) future an update to a version 2, this will then be a paid upgrade.
Hope that’s fine :slightly_smiling_face:
Hi guys, thanks for all the people purchased fleXon already!
I am just working on the next version and have added 5 new sections. Is there something you are missing so far and want to see urgently?
Not urgently but in the gallery I want to swipe from
One picture to the next once I open one in the lightbox
Hi Jan @Fuellemann thanks for the input!
This is unfortunately a function what is currently missing in Elements. The Lightbox is always linked to one picture only. In the Elements Gallery it is possible to swipe through the pictures, but then you are limited to the designs possible with the Gallery Component.
We have to see what improvements are coming to Elements. But as soon as this will be possible I will add it to the fleXon Galleries.
Thanks, can you bring this up with @dan ? It seems a kind of very useful feature not having to close and open each picture when displaying a gallery.
How about a horizontal timeline section capable of displaying family tree info and pic?
This is supported in the standard Gallery if that’s helpful…
Actually not as we need this support for custom galleries in the projects we can buy :slight_smile:
@hectorcam only to be sure, you mean something like the below screenshot but with additional photos?
Hi @dan
as @Fuellemann wrote, the Gallery component does not help in this case. It is for "self made” galleries made out of containers/images. I like to do the galleries in this way, because I then do not have any limitations on the design. The Gallery Component is a good Component but especially design wise a bit limited.
With the containers/images I can activate the Lightbox but only for every image separate. What would be really a great improvement when I can activate the Lightbox for every image in a container. Here are some examples.
Do you think that’s doable? If yes is this something you would take into consideration?
Yes that is what I was visioning and will you be able you link from one section to another?
