Hi I am new to website creation. Found getting to grips with the basics fairly easy for someone who has no website development experience.
I have run into a problem, it may be what I am expecting is not possible, here goes.
After creating the index and contact page I have done an export to view what it looks like on my local HD. I launch the site from HD using the index.html page, works fine, when i click on contact it only shows site tree. Can anyone please explain why this is happening.
Webpages are designed to be served by a web server.
If you want to “preview” your site ahead of publishing it to a hosting company,then you’ll need to either install a web server locally like MAMP(the free version will work) or use RapidWeaver by right clicking the page and preview in browser.
I have installed the free version MAMP, the problem I have is I have no idea how to tell MAMP to open the website I have stored locally.
I have looked at the documentation and some videos but they all seem to make assumptions that anyone installing such a product knows how to configure it.
Would be good if somewhere on RW site/forum there is a simple step by step how to set up MAMP for use with RW. If there is I have not been able to locate the tutorial and would be grateful if you can point me in the right direction.
