Dear all,
I was working our website and I found after publishing, that there are some squares next to my menu bar (see attached).
How can I remove them from there?
Thanks in advance for your suggestions.
Dear all,
Nothing attached. A URL would be easier for folks to help you out with.
Unfortunately that URL is a local address, like from preview in a browser.
Did you actually publish? If you haven’t yet a public URL even if it’s a test page would make it easier to get help.
Hi Doug, sorry, I was out of the office.
There you go:
paleoenvironment.eu
Thanks in advance.
V.
I think you’ll find they are there to indicate a sub menu.
Yes, I have seen that but, I don’t like them, I would like to have the menu without the squares, or at least I would like to change the squares to other symbols. Is that possible?
Should be changeable / removable in the Theme settings, if not contact Theme developer.
I usually see those squares when a theme is trying to use Font Awesome icons - like the downward pointing chevron - but for some reason, they’re not loading properly.
In fact, if you add this free stack to your pages - http://rapidweaver.marathia.com/stacks/fa4all/ - you should see your squares replaced by down arrows.
Rob
@ Dave and Doug, thanks a lot for the feedback.
@ Rob, thanks for the suggestion!! it works and it will be visible in my next update of the website. I already tried and check it on the preview page.
Have a great day!
V.
