What is the ideal pixel settings so that the full page shows up on a webpage? The default is 500px
When I change it to a larger number I get a lot of blank space below? Any thoughts?
Perhaps it is not too important to enclose the entire document in a frame? You could just use the default 500px and scroll?
Iām afraid there is no āidealā pixel setting for the PDF-frame in a web page. Obviously, it will depend on the dimensions of your PDF document. You will have to experiment with that. Publish your page and see how it looks. Then, go back to RW and correct the size setting. Then, republishā¦
Thanks Rob,
I had been using PDF viewer from RWtuts which automatically made it fit to the first page. Since they have gone out of business and are no longer supporting it it has been unreliable. I will figure it out!
Linda
PDF embed from Weaver.Space works well
I thought thatās what the post is talking about? only stack I know called PDF embed is Joeās.
We were. I had been using the other one and it sized automatically. I am now using Joeās and it doesnāt. That is why I asked the question. Thanks
Linda
PDF.js v2.2.228 (build: d7afb74a)
Message: Failed to fetch
I get this error with Crome but not with safari?
Any thoughts
Personally, I use the āEmbedā stack from @willwood and it works great for me. This stack makes it possible to embed not just PDFs but also HTML-5 audio and video, single images, directories of images and any iFramed content (and itās free).
