Pop-up warning on RW site
Hallo everybody,
I need to publish a pop-up notice like warning at the bottom of
www.bazar.it
(“Questo sito utilizza i cookie per migliorare servizi ed esperienza dei
lettori. Se decidi di continuare la navigazione consideriamo che accetti
il loro uso.” plus accept button)
How can i do with RW?
http://www.stacks4stacks.com/gateway/ should do the trick.
Try this one. I am using it myself: http://www.doobox.co.uk/stacks_store/demos/notify.html
You can do this with Joe Workman’s InfoBar. Or if you have Expose you can read this FAQ and modify it to suit your needs.
I do support for Joe Workman, so please check out his stacks and his GREAT Foundation Theme
