Problem with Google Analytics, visible on website
I’ve added the two Google Analytics codes to:
http://www.knotiverse.com/
http://www.tailtengames.com/
The codes are visible at the top of each page. It looks like the codes are in the correct places in the HTML. I am scratching my head on this one. Can anyone help please?
Thanks,
Murray
So, what is the problem? Are you saying you can see the code in the served page?, if so… I don’t see it.
There are black rows right at the top. Look carefully at the left and you will see the codes in a very dark colour.
I see, that looks like rhe analytics ID, did you actually past the html code in? Or did you just paste in the site ID?
I just pasted the ID number into the configure box for tailtengames.
But for knotiverse I first did the same, got the same problem, but then copied the whole script code into the HTML view source in RW. I noticed that I didn’t get a dot next to the “modified” page. I looked back once I’d saved it and it had reverted to the simplified format.
Are you putting the html code in the UI, under the spanner wrench there is a place for it. Sorry I’m on mobile right now can’t tell you exactly where it is, but it’s there. You can’t actually modify the code in view source.
@MurrayHeasman you have to paste the entire analytics code into settings > stats as @swilliam said.
Thank you both. That’s fixed knotiverse. I’ll do the other one now :slight_smile:
Hi guys Im just joining conversation about GA code. I am on RW 6.
I understand I place theGlobal Site Tag (gtag.js) ???
Is there only one place to ad the code or do I have to add it else where, please?
Many thanks
check this out:
https://rapidweavercommunity.com/tutorials/new-features-in-rapidweaver-7/adding-google-analytics6
