Problems with DIVIDER Component
I started using the Divider component today and encountered a problem with it.
I created three dividers and tried to set them to be 50% of the container width. On the first try, this worked just fine, and the lines were drawn at the correct length. But then I decided to modify them at different breakpoints.
All of a sudden, they all reverted to full size even though the properties were set to CUSTOM with a 50% width. After this happened, I could never get the width to change to any setting. I tried pixels, vw, rem, and %.
I’m not sure what’s going on here. It is worth mentioning that I had all three dividers selected, as I wanted to modify all of the properties simultaneously.
That sounds very strange, can you send over the project with the issue to dan@realmacsoftware.com :+1:
Aloha Dan, project sent via email.
Perfect, got it :+1:
I just tried previewing a project with dividers and noticed that they are not visible at all in Safari, even though they are visible in the editor.
Can’t seem to reproduce the issue here, can you do a sample project and send it over?
Aloha Dan,
I verified this in the project you sent me yesterday, so try that one to see if it shows for you. I tried two different projects, and both got the same result.
Hmmm, it still seems to work here…
Yes, that looks like it is working.
But scroll down to the FOOTER, there are three dividers in there and for me they DO NOT show up when viewed in Safari. The dividers are above and below the phone numbers in the footer.
Yup, that’s a bug, and I think it’s caused by your only globals issue you experienced in the past.
Just delete the dividers and re-add them. Will fix it for now.
