Rapid weaver Version 8.1 (20579)
PlusKit is being used…there’s an issue with that also?
just started RW 8.1 and it asks me to install the update to 8.1.1. But after doing this (installing and restart RW) RW is still v8.1 and of course it still asks me for the missing files. mhhh…
How do I have to proceed to get this bug fix to 8.1.1?
Please check if you are using the latest version of PlusKit at http://yourhead.com/pluskit and install the latest, if not, then restart RW. It might solve this issue…
checked the PlusKit version, it’s v4.1.3 (the latest) afterwards I have done the update procedure again, this time it worked as excpected :grinning:
alternatively the version 8.1.1 ist available from the releasenotes page as mentioned earlier.
now comes this tedious task of checking each and every RW project file for missing resources an relink them :tired_face:
isn’t there an easier way to get this done?
Looks like it’s there now. Don’t know if it was missing earlier.
https://dl.devmate.com/com.realmacsoftware.rapidweaver8/20595/1548436029/RapidWeaver8-20595.zip
I don’t believe so.
No updates are publishing for me either. Hope this is fixed soon!
I had the same issue. Unfortunately I closed the warning window and said to do it later. Then published. It killed my project by asking to re-link more than 50 resources - what a pity. DO NOT upgrade to 8.1.1 until they fix this.
Just tried 8.1.1 and projects will not save ?
Alan
And why would you still be using pluskit…partials are so much cleaner.
Just my opinion!
Perhaps because they do very different things?
This!..partials are combined stacks, I’m using pluskit to import into a plugin page.
Also it looks like a number of Joe Workman stacks are broken, will contact him directly.
Chasing the Apple sandbox is a definitely stupid path to follow, but hey, lemmings do what they gotta.
I have a whole bunch of @joeworkman’s stacks and don’t think I found any “broken”. Joe has been very active in testing all the 8.1 betas.
Video wall, broken. If i load the project in RW 8.0.3 the feed is visible in preview.
Load the ‘sandboxed’ version of the project into RW 8.1.1, feed broken
Tested that?
Also Forefront’s Rapidcart Pro plugin appears to have broken, again, absolutely fine in 8.0.3. Anyone with insight there? All the product thumbnails are broken (in spite of me never moving them, and certainly no prompt to relink them). Sandboxing is a terrible idea, i hope the community here voiced dissent. It’s never worked, never will.
Video wall is working OK for me. Also, almost all my stacks are from Joe Workman on all my projects and I don’t see any that are not working.
What are you talking about when you say sandboxed version?
You said a number of @joeworkman’s stacks are broken, indicating more than just video wall, what other stacks? I don’t have video wall but Gary @Ruyton seems to not be having any issues with this.
Might want to be a bit more specific with the issue you’re having otherwise folks won’t be able to help you out.
Perhaps @gibo or @rob can help you out.
I see a lot of the features on the Rapidweaver 8 themes are not working either.?
Could you be more specific?
FFS people, if you are having a problem be descriptive, provide a link, upload a screen shot, tell us the version of MacOS you’re running … BUT DONT just post stuff like “xxx is broken, why?” and expect anything other than derision, or a reply like this.
K I’ll stick with poster stack, thanks :slight_smile:
Why again? Please be more specific. Contact us at help@4gnd.com attaching a test project affected by the problem.
BTW, it’s Foreground.
