Resource Scan Folder – relink resources dialog
I can’t get the ‘Scan Folder…’ button to work. Doesn’t do anything even if I locate the exact folder the resource is located in. What is it suppose to do? I would expect it to work similar to Adobe Indesigns Relink / Relink Folder feature.
When I update a missing resource – the lis – meaning I can’t verity the name before relinking. This is a problem if you are a man and have more than 3 resources you need to remember!
And this is another Resource problem. The last part of the path is hidden – and users can’t see what resource is missing – if the path is a little longer than normal.
Tagging @tpbradley
