Responsive text size problem
This is copied from another post;
I am designing my responsive layout but I am having trouble with sizing my text. When I go to a larger layout, I cannot make my text larger unless I use the text style box. The problem is that there is no override. When I try to change the text size by overriding the text box, the text does not enlarge.
Sometimes it works sometimes not. I have many pages repeating this lay out.
Clicking the “size” will change the spacing but not the text.
I think that other thread was more to do wth overides on different screen sizes. This is how it works for me -
Even if it does not change on screen, does it change when you preview the site?
@TomM, I think it’s because you have double-clicked into the text component and overridden the text size. You need to remove the styling inside of the text component.
I hope this quick little video helps:
Yes, Clear Formatting.
