Responsiveness in properties
Hi @tpbradley
as discussed before. A small feedback regarding the responsive stuff. Would it be possible to have the response part as a variable like the {{value}}, then in the format it would be easier to handle, Instead of doing a recalculation as mentioned here: link
Use Case
When equal sizing is required
Suggestion
{{device}}w-{{value}} {{device}}h-{{value}} → w-12 h-12 md:w-6 md:w-6
@dan … Love the new debugger.
Hi @Beblebroks,
This looks like a bug - it should work in the way you have suggested (but without the need for the {{device}}), so doing "format": "w-{{value}} h-{{value}}" in your properties.json should output something like:
w-12 h-12 md:w-6 md:w-6 lg:w-4 lg:h-4
We’ll take a look and get this fixed up ASAP :slight_smile:
@Beblebroks, check out today’s 0.6.1 release :smile:
Works :scream:
