small feedback about the behavior of properties. As an example the switch. If used with the responsive: false it will return a boolean. When using the default one it returns a string.
That behavior makes sense, since the breakpoints will be added to the value.
I would just stress that out more somewhere maybe in the docu, not sure if I found that there. false and "false" will show up in the debugger as the same, so it took a moment till I realized what the problem was. And I assume that will be the same problem for numbers and so on.
