I’ve used a container to create curved borders on all the 4 corners. But the TL en TR corner stay hooked.
Hey @Bartje,
That’s very strange. I’m wondering if you need to switch the “overflow” option in advanced to “Hidden”.
Can you share your project with me, send it over to dan@realmacsoftware.com and I’ll take a look at fixing it up for you!
Hi Dan,
I don’t see the option to switch the overflow option in the advanced part of the settings of the container.
The problem only seems to be related to the mobile breakpoint view. In the other views, the corners are rounded as set.
Ah sorry, that’s coming in the next beta ![]()
Oh strange, if you can email me a sample project I can take a look and see what’s going on.
Hmmm, it’d be good if we had an easier way to share projects ![]()
I’ve sent you the testproject with weTransfer. You don’t have to look at it anymore. I’ve just installed the latest update and the problem seems to be solved ![]()
I’m not 100% sure why this is happening on Mobile (I’ll need to dig into it some more).
For now, you can set the overflow to Hidden on the Container. You’ll find this setting in the latest beta we’re releasing today (Build 22880). Here’s a video showing how to do it…
