Hi all, it’s the end of 2018, and I’m wondering if there are any stacks now that support full MySQL CRUD.
David
David
Yes, EasyDB
Stack-Its: https://www.stack-its.com/stacks/easydb.php
Bill
Stack-Its
Hi Bill, thanks for responding. I’m playing with EasyDB demo. I’ve managed to install, setup Credentials and Database. I’m trying to add/edit a DataGrid. I’m going through your Vimeo training. I’ve added the table, two fields. Loaded and reloaded cache… I’m not getting any errors, but the grid is not showing. Anything off the top of your head I should look for?
David
Hi Bill
I’m facing te same issue: the page remains blank without any error alert. Connexion helper is giving this information:
Also, the login page configuration doesn’t work and the ring is still red.
I would appreciate your help before purchasing.
Zden
