@elementsbot It is great to have many icons available in the Core section. Now I want to find a special icon and I am missing a search feature in Elements to find the needed icon quickly. How do I do this?
Search
Found 51 results for 'icons search Elements SF Symbols icon picker search feature Core icons order:latest'
Browse Web
Browse Web
Reading https://docs.realmacsoftware.com/elements-docs/elements-language/bundle-structure/icons
Browse Web
Browse Web
Reading https://docs.realmacsoftware.com/elements-docs/search?q=icon
Search
Found 51 results for 'Elements icon picker search SF Symbols property icon name paste order:latest'
Hey Jan! Short answer: there isn’t a built‑in icon search in Elements (yet). The Core icons are SF Symbols, so the fastest workflow is:
- Use Apple’s SF Symbols app to search
- Pick your icon, copy its name (e.g. paperplane or paperplane.fill)
- Paste that name into the Icon control in Elements
- Tip: In SF Symbols, set the availability filter to your macOS version to avoid missing icons (Ventura/Sequoia differences can bite)
References:
- doc.txt and the Elements Manual both recommend using the SF Symbols app for icon name lookup. See the Manual at Welcome | RapidWeaver Elements Docs (Resources section).
- Related forum thread: Icons in properties: is there a list? Icons in properties: is there a list?
If you’d like, I’ll poke the Big Chief: @dan — icon search in the picker would be a lovely QoL upgrade. Pretty please?
PS: Elements Bot might be slightly unhinged and occasionally wrong — and Elements changes fast — so shout if this doesn’t match your build.
We have a search filter at the bottom of the panels… it’s pretty nifty ![]()
@dan I do have downloaded the SF icons from Apple. Is there a way to import/add all these icon to RW elements in the icons section? Or any other icon svg library?
@elementsbot How do I add icons from the SF-Symbols app to RW with a step by step instruction
Short answer:
- You can’t import the entire SF Symbols library into Elements’ Core icons. It’s huge (and Apple’s license is… particular).
- You can use individual SF Symbols by exporting SVGs, or wire up a web icon set (Ionicons, Heroicons, Font Awesome).
Also: Dan’s right — use the search field at the bottom of the left panel to filter what’s in Core.
Step-by-step: use SF Symbols in Elements (SVG)
- In Apple’s SF Symbols app: find your icon, set Availability to match your macOS (Ventura/Sequoia), then File → Export Symbol → SVG.
- In Elements: open the left panel → Resources. Create a folder “Icons” (optional).
- Drag your exported SVG(s) into that folder.
- Use it:
- Easiest: drop an Image component and pick the SVG.
- Best control: drop an HTML component, paste the SVG markup, and style with Tailwind (e.g. add class=“w-6 h-6 text-slate-600”). If the SVG isn’t coloring, set its fill to currentColor in the SVG.
Alternative: add a web icon library (site‑wide)
- Ionicons (simple + works great with Tailwind)
- Add this once (Project/Site Settings → Code → Head). If unsure, see “Resources” in the Elements Manual.
- Use in an HTML component:
Tip: size with Tailwind text-* (Ionicons size follows font-size).
- Heroicons: copy SVGs from heroicons.com and paste into an HTML component (no JS needed).
- Font Awesome: add their CSS in Head, then use . Easy, but SVG/inline icons are usually leaner.
Good to know
- License: SF Symbols are fine to export as SVGs for your site, but don’t bulk ship the whole set or modify shapes — read Apple’s license.
- Dan posted a Social Icons example using Ionicons: Social Icons Component (nice pattern to follow).
Docs and references
- Elements Manual (Resources + Component Styling): Welcome | RapidWeaver Elements Docs
- Related forum: “Icons in properties: is there a list?” Icons in properties: is there a list?
- Our internal doc.txt also recommends Apple’s SF Symbols app for icon name lookup and using exported SVGs.
If you’d like, I can whip up a tiny “Icon” custom component that takes an icon name and renders from Ionicons or a local SVG folder. Ping me. And @dan, consider an “Icon Picker” with SF search? Elements Bot says pleeeease.
PS: I’m a cheeky AI in a fast-moving app — I can be wrong. Shout if anything doesn’t match your build.
@elementsbot Thanks. I do not want external links to pull icons but I need to have the icons in the icons folder in the resources. So I would need to import all the icons of an icon library into RW and have them available for all projects
Browse Web
Reading https://docs.realmacsoftware.com/elements-docs/search?q=Resources
Hey Jan!
Short, honest answer:
- You can’t import the entire SF Symbols set into Elements’ Core icons, and you can’t extend Core. Apple’s SF Symbols license also forbids redistributing the whole library.
- Resources are project‑scoped today, not global. So there isn’t a single “icons folder for all projects” you can wire up once.
Good, workable options (local, no CDNs)
- Base Project/Template (recommended)
- Create a “Base Project” with Resources/Icons pre‑filled (your chosen SVGs).
- Duplicate that project to start new sites so the icons are “there” every time.
- Manual: see the Elements Manual (Templates + Resources) for the flow: Welcome | RapidWeaver Elements Docs
- Bundle icons in a Custom Component
- Make a component (or pack) that ships the SVGs inside its bundle and exposes a simple “Icon name” or “File” control. Install once, use in any project.
- This avoids external links and keeps everything local and reusable.
- Local third‑party sets
- Heroicons (MIT), Bootstrap Icons (MIT), etc. Download the SVGs, drop only the ones you need into Resources/Icons, then:
- Use Image component (simple) or
- Paste SVG markup into an HTML component for Tailwind control (ensure fill or stroke is currentColor so text-* colors apply).
SF Symbols specifically (local only)
- You can export individual symbols from Apple’s SF Symbols app (File → Export Symbol → SVG) and drop them into Resources/Icons. Don’t bulk-ship the full set (license).
- Tip: in SF Symbols set Availability to your macOS version so you don’t pick a symbol that won’t render on older systems.
Search inside Elements
- Use the search field at the bottom of the left panel to filter your Resources/Icons folder quickly (Dan’s not lying — it’s nifty).
References
- Elements Manual (Resources, Templates): Welcome | RapidWeaver Elements Docs
- doc.txt and the Manual both point to using Apple’s SF Symbols app for icon lookup.
- Related forum threads:
- Icons in properties: is there a list? Icons in properties: is there a list?
- Social Icons Component (pattern you can adapt for local SVGs): Social Icons Component
Feature idea
- A “User Icon Library” / global assets area + an Icon Picker would be a great QoL upgrade. Paging @dan and @ben for the wishlist.
If you want, I can post a tiny “Local Icon” component that inlines an SVG from a Resources/Icons folder by filename and respects Tailwind color/size — totally local, reusable across projects.
PS: Elements Bot lives in the forum walls and sometimes hallucinates. Elements also ships fast, so details can change. Shout if anything doesn’t match your build.
@dan Excellent, I added a resource pack with the Bootstrap icons and this will be part of any project I work with ![]()
Awesome, that’s exactly how it should be used
Enjoy!
