Site Slogan Beneath Site Title - Help!
Hi Everybody,
Is it possible to place the site slogan underneath the site title?
SITE TITLE GOES HERE
site slogan goes here (underneath the title)
I am using the foundry theme & stacks.
I have tried using a simple
in the built-in rapidweaver site title section but the line height is too big and bleeds into the banner area.
I want to keep both title and slogan within the nav bar area.
Look forward to someone’s help.
Cheers
The Foundry NavBar stack by @Elixir can include the Site Title or Custom text in it. It doesn’t have the ability to also include the Slogan below the Site Title. That would be quite a bit of text to keep in the actual NarBar, and probably wouldn’t work very well.
I don’t quite follow what you’re trying to do. Perhaps a screenshot or two would help us.
Something like this:
I wonder if a little CSS hack might do it… not sure how the page is formed.
If you can share a demo page someone might have a suggestion :+1:
So something like this?
That’s the one. Just like that.
I just created the Title and slogan and saved them as a JPG, then used Foundry’s Mega Menu stack to create the menu. There’s an option there for you to drop in your own logo.
Thinking about it, you can also do the same with the standard Nav Bar stack. Just removing the Branding option, and use either the Rapidweaver site logo or Custom settings.
Rob
Hi Rob,
What I would like to do is be able to create a Title and a Slogan and have the Slogan below the tile (as text/font, not an image).
Hope this makes sense.
Cheers
Kevin
This could probably be done. Before I outline how you could do it, I’d like to second the recommendation to use a graphic.
They way you’re showing it, it’s more like a logo than a title and slogan. You’ll be able to get the fonts sized properly, especially if you’re going to have the slogan the same width of the title, if it’s done as a graphic. This can be tricky across different browsers and operating systems just using fonts and font sizing. If you are not going to be that particular about how it looks and not care if it varies for different users, then I’ll layout how you could do it.
