Is there an example of how to correctly set up the SIZING properties for a custom component to match what is used in the core components?
It seems to need a particular set of values in addition to allowing the user to turn off the theme settings and enter their own. Seems like there should be a themeSizing property block that has the correct values. There are already ones for most of the other theme properties, but not for sizing.
There are a few other examples that would be very handy, as I feel it is incumbent on a component developer to match what is being used in the core components where possible, to avoid user confusion.
There is also a size- utility in Tailwind that will set both the width and height at the same time, in that case you could just do: "format": "size-{{value}}"
I can’t seem to get this to work. Nothing happens when I change the value. Is the above the correct format?
When I look at the tailwind docs for “width” the only ones that match are “w-auto” and “w-px”. None of the other classes match those shown in the drop down, instead they are things like “w-lg”, “w-xl”, etc. How do I convert the value to map to these classes. Unless I’m looking at the wrong version of Tailwind (4.1)?
