Hi everybody.
What is the best solution (better if also economic) to add social buttons to a page (I use the Multi FlexBand theme) in Rapidweaver 8?
Thanks for any help! ![]()
Alberto
Are you using stacks pages?
The theme doesn’t appear to have any Social Media built-in.
So you could (and would have too if not using stacks) do it manually.
Stacks 4 Stacks has an easy to setup ShareStack. There’s a free demo version you can try before you buy.
Thanks! I’ll try. ![]()
It supports something called ‘Awesome’ icons which may give you what you want. They’re described here (https://www.multithemes.com/examples/flexband/features/). And there’s a sample project there you can download which may include examples.
Rob
