I’m trying to find out if there is a way to adjust the height of the Navigation bars (specifically the top one). I can’t seem to find anything looking at any of the CSS’s. I thought maybe the height settings under the Nav sections of the styles.css would be it, but changing them has not effect. I’m not exactly an HTML expert, so…
Well that go me somewhere thank you. That adjusted what apparently is the foreground of the Nav bar… seems there is a background as well and the Link Text alignment that needs to be adjusted.
Apart from not really knowing the Tags (which are easy enough to find online), I guess I don’t understand which CSS controls what exactly and/or how they integrate with each other. Sorry for the ‘noob’ questions, but I learn fairly quickly.
Not sure where I put this code. If I put it in CSS the top Navigation bar just gets higher/thicker. I want it thinner (the 30-50px) works, but that code doesn’t fix the height of the grey background. Oscars image above illustrates the problem perfectly.
Need to revisit this question. See the below images. In RW preview the top menu bar condenses to a dropdown when the screen browser window is shrunk and/or in phone view.
This doesn’t work or I should say the dropdown ‘bars’ don’t show up with published pages in web browsers nor on phones.
