Hi!
Is there a stack for animation of objects with a time interval? For example, the object appeared to some, had disappeared, then after a specified time reappeared.
If you use my Foundation theme, it ships with an animate stack that does this.
Joe, thanks, but interesting separate (individual) stack.
Thank you, but without additional code they are hardly suitable for this purpose. That is, it will be necessary to search for a code of appearance and hiding, and then add it to the field CSS or Java, if I’m not mistaken.
You could use a slider stack and have 3 (or more slides) images/icons that flow through … dissolve in/out, etc.
