“Animagic will not work with that sort of locked scrolling effect that the theme is using. The trigger the animatic needs, which is the page itself scrolling, does not happen with that sort of theme. I have a theme of my own that works the same and Animagic does not work with it either. It is just how the code works.”
I am now looking for an alternative stack that will enable me to achieve the same ‘animated’ function but which is compatible with my theme.
If anyone has any suggestions I would be very grateful!
I think that Doobox’ Jet stack may help you out here. I know one of its features is the ability to animate content when other stacks can’t (for whatever reason)
Thanks for the help with this. I downloaded the Jet stack from Doobox but it doesn’t seem to be working with the Streamline theme… When I add the animation, and then try to preview the page, the scrolling function will no longer work on the page at all. I wondered if it was just a problem with the ‘preview’ so I published the page live but it was the same problem. As soon as the Jet stack is included anywhere on the webpage then that page won’t scroll at all.
Not sure how to fix this. I tried unchecking the ‘Stacks Breakout’ and ‘Theme Breakout’ checkboxes in the Jet settings but this did not resolve the issue.
@Doobox, do you have any other suggestions I could try?
