Tags with Globals
I am using a global to create multiple cards of motorbikes. The tags look like above.
Reverting it to a non-global and it works.
Eeek, I’ve not tested Tags in globals! We’ll dig into this now and find out what’s going on and get it fixed.
Hi @dan,
forgot to mention. Tags can not be overwritten in globals. Approach would be the same like you showed for when to use Globals.
Ah-ha! Just looked into this now with @tpbradley and it’s because it uses collections!
So, yes, right now Collections won’t work with Globals — this is on the list to be fixed!
Thanks for the report :blush:
oh man yeah right :man_facepalming: … We talked about that before. Logical. Should have known.
Cheers :beers:
