Bug (Hmm Maybe) Could be Better Lets Say
So regarding “Tags”.
Lets say you create a nice product card global, and use it repeatedly in a grid.
I don’t “Think” I’m able to change the tags on each of those global cards independently. No way to override the tags from the global.
I can workaround by wrapping each of the global cards in a container, to hold the tags, and be the filterable item. But defeats the object of the global in respect of maybe wanting to change from dim, to zoom, or slide.
Basically can tags be made to be overridden from the global?
Hi @Doobox,
I am using the global at the moment as a template with all “tags” and just remove the once I wont need after unlinking it.
But I don’t seem to be able to unlink tags?
If I Change “IOS” there all tagged “IOS”
I thought overriding the container its self me do it, as thats what the tags belong to, but it doesn’t. Tags still remain global to the global container.
Ohh .. yeah that thought makes sense.
But yeah I always unlinked it and then edit it. Screwed me up once or twice, when I forgot that at first :smiley:
Yeah, this is a current limitation with collections within globals. We have plans to add overridable collections in a future release, though I can’t say when we’ll get to it.
It’s fairly easy to workaround, wrapping the global card (containers) in containers set to “grid item - 1 column”, and then making those filterable, and holding the tags. Just caught me thinking I was holding it wrong.
