The document “?.rw8” could not be opened
worked ok 2 days ago but not now
Any ideas?
I’m having the same problem. Projects aren’t saved in RW8. Impossible to rely on, therefore unusable until fixed.
Back to RW 7.
Is it happening on a single project? It appears these maybe two different things from both descriptions? The original post says could not open, the second post says projects aren’t saved.
Anyway I think more information on both issues would be needed to help get them resolved.
Hi
I think this issue arose due to the fact that I was storing my projects in the cloud (Dropbox)
To me it appears there is an issue in synchronisation.
I have moved my projects.
I don’t think Rapidweaver is at fault here just my understanding ie:- misunderstanding
If this is noted somewhere in the literature I missed it.
Thanks for your comments
