If I’m seeing it correctly, there’s now an option in the font family section in Theme Studio to add custom font files. It says ‘drop font resources here.’ However, when I drop them, nothing happens. Is this not working yet?
Hey @Bartje,
You’ve been able to do this for quite some time but it’s probably not as obvious as it should be. You have to add the font to your project resources, then drag the resource into the theme studio.
Thanks for the help. This works but only if I drop them one by one. When I drop a folder of fonts, Elements crashes. When I select multiple fonts and drop them, only one is added to the Theme Studio.
This is not so user friendly. Maybe it’s beter to change “drop font resources here” to “drop fonts here from your resources folder” or something like that.
Yeah, the UI here isn’t great here. We’ll get it fixed up in a future build.
Cheers
