Top bar drops down a line when moving between breakpoints
I have a menu that has a solid background just above a background picture. When I shrink the page, between the full size, which is ok, and the mobile, also ok, the menu drops down a line and I can’t see it.
desktop
mobile
in between
the web site is https://gigl.org.au/test-home/#!calendar
any hints?
Julia
Not sure why it’s happening. Looks like bug in top-bar
This CSS looks like it fixes it:
ul.title-area.title-area-site-setup {
    margin-right: 0;
There is an easier way to do this. In TopBar, there is a setting that says Full Menu At, change that to Desktop only and it should make it a mobile menu when it gets too small like that.
thanks Doug
I will give both of these a go.
thanks Robert
I will try this - but presumably it will then use the mobile menu on the ipad?
J
Yes, it will be the mobile menu on iPad, at least in portrait mode
