Typography Component Issue
Dear Dan,
Please see the attached video for an issue I currently face with the typography component.
Thank you
I have also encountered this problem and reported it separately to Dan. It does also affect the Text component but with different settings. If you have a custom font size and try to set it for the Text component it is not applied. You can however apply it if you select the text in the component and then use the inline editor to apply the custom font.
Thanks for also reporting this problem. I was beginning to wonder if I was the only one seeing it.
Thanks for the reports; the video was super helpful!
We’re looking into this now and will ship an update later today (hopefully).
@mmohdher @handshaper, New build is up! Give it a whirl and let me know how you get on :blush:
@dan The typography component does appear to be fixed I’ll be doing a lot more testing during the day.
However, there is still a problem with the TEXT component, where I cannot assign a custom text size to the component. It shows up with the name of my custom size but it is not applying the actual size.
This is fixed in today’s build (due shortly) :tada:
@dan Indeed it has, much appreciated.
However, I have now discovered a problem in the TEXT component. When you set bold, italicized, or underline text in the inline text editor, it is not displayed correctly in the editor. But it is correct when displayed in the browser. This is with the 0.7.0 version. It also appears to be affecting the size setting as well.
I cant seem to override text settings anymore? the button clicks on but text just moves up and down a bit. ah its affecting the breakpoint after the one im trying to change…for eg if I override mobile landscape the iPad portrait is changing not the mobile landscape
Yikes! Thanks for the report, we’ll get this fixed up for the next build!
