Hello all,
I wonder whether it is possible to align rows (in multi-column stacks or block grid) vertically centered. I´m trying to have images vertically centered in a row but could not manage it. Maybe I’ve overseen something obvious…
Hello all,
Take a look at big white ducks vertigrum.
http://www.bigwhiteduck.com/stacks/vertigrum/
Yes, Vertigrum should do the trick. Otherwise – especially when your site is not Foundation-based – you could try the Reflow stack from Doobox: https://www.doobox.co.uk/stacks_store/demos/reflow.html or the Grid stack form DeFliGra: http://www.defligra.com/grid-stacks/thegrid-stack/
Thank you very much! Vertigrum did the job
Doesn’t Vertigum require Foundation and the Site Styles stack?
If not, how did you get it to work without Foundation?
Thanks!
There are still a handful of ‘Foundation-only’ ones and it looks like Vertigrum is on the list (you can find a sortable list here https://bigwhiteduck.com/stacks/). Most are Foundation-independent though. Sections Box, for example, has a vertical centre option (among a thousand other options) and would probably be a good option, @soltmann.
