September 28th, 2015 - I’m very happy to announce that the latest versions of all 26 themes from YuzoolThemes are now Waterfall compatible.
Additionally, I just noticed that Gary of Kuler Solutionstweeted that all themes created in 2015 and going forward are Waterfall compatible.
###What is Waterfall?
Waterfall is a theme updating and backup tool, which allows you to easily see what version of a theme you have, if there is an update available for it, and then automatically download and install that update directly inside RapidWeaver.
Before installing an update, Waterfall makes a backup of your existing theme, so that you can always go back to a previous version if need be.
###What themes are Waterfall Compatible?
All themes from the following developers, unless otherwise noted:
Hiya thanks for the heads up of the developers who are Waterfall compatible.
however have i found a BUG ?, I notice that the 5 new themes that are bundled with RW6, are not shown in Waterfall !, despite 2 of the 5 new theme developers are in the list above !!
Hey Tim, it mentions somewhere in Waterfall that duplicated/renamed themes and themes that come bundled with RapidWeaver will not show up. Not on a computer that has Waterfall right now, but they are not supported by Waterfall.
@timmytoad We do plan on adding support in Waterfall to update duplicated themes (ones you copy from within RapidWeaver). The built-in themes, however, are located separately on your Mac and don’t have the required bits needed for Waterfall to check for updates to them.
