The installer will not work, open the disk image, on it is a folder called Resources, in that folder is the stack, drag and drop that on the RapidWeaver icon in the dock, that will install it.
Dear Tav, Scott, Zeebe, et al,
I am still going nuts with this problem.
I’ve set up a test site at http://www.poorplayers.org/Test/index.html
It just has 3 pages. Attached are screenshots of the 3 pages in edit mode
Notice I’ve added the CSSbox (with class=clearfix) and it seems to do what we want it to do,
Here’s the Current Productions page in edit mode
It also seems to work
Here’s the Future Productions page in edit mode
Again, I used a CSSbox to enclose the block of ordinary columns, and otherwise I have used the Foundation columns.
Lots of problems:
- The columns are all mishmashed and essentially put into one column
- While the Home link works, the link to the Current Productions page doesn’t.
Can you help me figure out what is going wrong?
@MarthaL - Not sure, but It doesn’t look to me like you actually have the foundation theme attached.
also a CSS error on the page , may be related.
Make sure you have foundation selected as the theme and republish
I woud say Scott (@swilliam) is correct. looks like you are using the simple business theme. Fondation columns need the fondation theme to work correctly.
You folks are all wonderful! Sorry I didn’t get back to you before, but I was in Wash., DC and then was super sick. Anyway, thanks to your help, the website is up and running. If you want to see it, it is
I’ve also used your advice on my home page at
http://www.marthal.com
