Abuot Audio Component
What audio formats does the Audio component support? I can’t select my .mp3, .wav, and .m4r files from the folder—it only seems to allow .mp4 files.
​Also, I don’t know any code or programming languages; I chose Elements precisely because it lets you build a website like you’re putting together LEGO bricks. So, I have a small request: Could you possibly add a feature to the Audio component that allows users to download the audio file? It would be great if it could both play the audio and provide a download option for visitors.
Thank you!
Welcome :hugs:
I’m not sure…
Got 80 players up playing .mp3 at Windytown.com
Works fine….
Are you selecting it / dragging it to the correct box?
Thank you for your reply. I see now that it works with drag-and-drop; I had been using the choose button to choose the file from the folder.
​I took a look at your website. I want to build a page similar to yours, but with a separate download button for every audio file. The only problem is that I don’t know any coding.
At onesongeveryday.com I have the files on Google Drive and linked from the website
The listener clicks it - opens a new window with a standard player, in the player is usually an option to download!
Not very elegant - but it works….
Our third world countries can’t access Google Drive, but we still hope the audio component can provide a download button. I see that the audio component can customize buttons, but only limited to the few buttons provided by the developer.
Just add a link or button below the player, you can then link to any resource in your project.
Under the custom attributes, add a new attribute and name it “download”, this will tell the browser to download the file, not open it. You can also give it a custom value and that will be set as the download file name.
value: name-of-your-file.mp3
Hope that helps.
I didn’t know this… that’s very cool :smiling_face_with_sunglasses:
Wow, that’s amazing! Thank you!
