Accessibility and alt text?
In an interview I was doing, the author talked about how you should make your sites accessible, as it improves your SEO results. So, I resolved to look for accessibility features in Rapidweaver, as that’s how my site’s created. And, I can’t find any way to add alt text to the images therein. Yes, I could do it outside, and reload them all, but given that I can add alt text to images in Word, I’m thinking I should be able to do it in this tool. Any guidance? Am I missing an obvious tool? I don’t see it by right clicking, nor in the Resources pane. Thanks!
Depends on where you are trying to add the alt text. For example, if you are trying to add alt text to an image you’ve added to a Styled Text page in RapidWeaver Classic, you’d just double-click the image and add the alt text in the Alt Tag field:
If you are trying to add alt text to an image on a different page type, let us know the page type.
Of course, right there. Double click, not right click! Doh. Thanks!!!
