I am running an add financed site, and I need som advice on how to put in a snippet or something else that tells my users that they have to allow this site in there add blocking app .
Can anybody help me with that
Regards Peter
Regards Peter
oh you mean advertising blocking as in “ad blocking”? Ok. The add misspelling was a little confusing.
Well, there are a few ways to do this, I believe.
You could use Joe’s call to action stack (which appears after a period of time).
Thank you @devananda
Sorry about the misspelling. I will look into the call-to-action stack
Regards Peter
In addition to the call to action stack, there’s the Notify stack from Doobox, with 50% off at the moment too.
I have watched the video for call-to-action. But i don’t believe that this is what I really need. What I need is a snippet that checks whether the user is using adblock and if so to tells the user to allow this site in adblock.
I believe that call-to-action and Notify stack are both thought the other way around - I mean to increase some customer interest in order to get more customers and more trade. But perhaps I am wrong here
Offered without warranty. I make no comment as it to it’s correctness or the rights or wrongs of hassling people about their ad-blocking preferences. Drives me potty when I get messages like this personally… but there you go.
So, for a bit of fun…
This is a snippet I picked up somewhere online a while back. It might at least get you started.
Add this to a html stack at the bottom of your page. Remember to clear/ignore formatting etc.
<div class="afs_ads"> </div>
<script>
(function() {
var message = "It appears that you have ad blocker software enabled! Please disable it for this site and help support our work!";
// Define a function for showing the message.
// Set a timeout of 2 seconds to give adblocker
// a chance to do its thing
var tryMessage = function() {
setTimeout(function() {
if(!document.getElementsByClassName) return;
var ads = document.getElementsByClassName('afs_ads'),
ad = ads[ads.length - 1];
if(!ad
|| ad.innerHTML.length == 0
|| ad.clientHeight === 0) {
alert(message);
//window.location.href = '[URL of the donate page. Remove the two slashes at the start of thsi line to enable.]';
} else {
ad.style.display = 'none';
}, 2000);
/* Attach a listener for page load ... then show the message */
if(window.addEventListener) {
window.addEventListener('load', tryMessage, false);
} else {
window.attachEvent('onload', tryMessage); //IE
</script>
This surely works. But the message only shows once. I would like it to show every time a user enters the page if adblock is enabled on thus domain. Can you help me fixing that
Regards Peter
I think that that this JS only works if the user has AdBlock Plus installed. There are many adblocking plugins. I don’t believe that it will be possible to detect all of them.
OK - Thanks. I believe that AdBlock Plus is the most used, so I am good now. Thanks for your help.
