Hello,
I would like to create an animated background. Best would be to put three or more png-images in the background and they are moved randomly. I also should be able to control the time of the movement.
Should look a little bit like this:
https://www.osbe.ch/lernen-und-unterricht/offene-schule-bern?frame=264
Perhaps there is a stack I could use witz Elixir Foundry or Rapidweaver Foundation, otherwise an easy to use code would also be fine.
Thank you all for your help.
Regards
Hansjörg
