I have three sites nearly identical in format, all based on Aqualicious. When I try to load one (http://gscookie.co), get an error message: “The (null) theme that this document uses is missing. If you open this project, RapidWeaver will apply the Offroad theme.”
First, I know Aqualicious is there, because the other two sites work fine.
Second, when I select “Apply Theme and Open,” nothing happens. The file does not open.
Everything was working fine until a few days ago; don’t think I changed anything.
Aqualicious is a very old theme. I don’t think it is still included with RW, but I may be wrong. Try to switch to another theme (not one of “blank” themes) and see what happens.
Hi, this usually happens when you store the rw-file on a server and work from there. If this is the case, check on your server if there are any recent backups. If so, copy it on your desktop. Perhaps on these backup-files the extension .rw is missing and you have to add it. Then try to open it.
I had the site stored on iCloud (along with another site that is working just fine), so I did both a limited (folder specific) restore and a full iCloud drive restore. Still getting the same error message.
First of all, make a local copy of the site that works on your computer to be on the safe side.
Then check if you have a time machine backup of the corrupt file. Restore this one on your local computer.
The one on the iCloud Drive seems to be corrupt, and this can happen any time you work with a project from a server IMHO. For better practice, only work local and save a zip-compressed file to iCloud Drive only for backup purposes.
I think the problem is identifying the corrupt file. I did restore the site file (Blue icon, file type = RapidWeaver project) from Time Machine, and it still doesn’t open.
