Printery
(Humberto Hernandez)
7 September 2018 20:43
1
I am using the “Poster ” by InStacks Software. How do I split my long text, so I can use the “read more” feature? Is there a trigger or special character? What decide the amount of lines of text before it shows the ”read more” words?
Thanks’ in advance.
Humberto
Sunny Puerto Rico
instacks
(Jannis from inStacks Software)
7 September 2018 21:05
2
On each Poster Item, you have in the stack settings a “Summary Content” option.
If activated, you will get another content area in the edit mode, where you are able to place text.
You are also able to decide if the summary content will be displayed only in list, or also in the details view.
Cheers, Jannis
inStacks Software
Printery
7 September 2018 21:07
3
Thanks’ Jannis for your fast response.
Humberto
Sunny Puerto Rico
Printery
7 September 2018 21:19
4
Danke 'Jannis … du machst meinen Tag.
Gracias,
Humberto
desde el Soleado Puerto Rico
system
(system)
Closed
8 October 2018 07:19
5
