Looking for code I could use to set a dividing line between each brick with some padding above and below the line…
@Elixir
thanks, Lisa
No code needed. Insert a One Column stack (you know the one that comes built-in to Stacks) into a Bricks item. Set your border and padding on that One Column stack. All done.
So I have to add it in each brick? Kind of time-consuming. I’ve done this before with code for my blog and a couple of other similar stacks. Wouldn’t something like the below work? I just don’t know what the ‘name’ would be to replace ‘.blog-entry-body’
.blog-entry-body {
border-bottom: 2px solid #808080;
padding-bottom: 16px;
Just create a partial of that One Column stack if you’re using it a lot and drag-and-drop copy it in each Bricks item.
I know how to do it. Doesn’t matter if I use partials or just a line stack. Still takes extra time to add each stack. I was asking for page wide code, which would save a lot of time.
thanks
Might try:
.bricks-item {
Yes, perfect, thanks @teefers
